2G What do i do with the two air intake hoses?
Eclipse 1998
240
33
Jul 21, 2010
Bloomington, Indiana
So i just received my fp intake pipe(non-recirculating), and I'm not to sure about what to do with the vacuum lines.I'm running a non recirculating BOV and i put a little filter on the line that runs to the left of the valve cover, but what about the one my mbc runs to, and the other hose coming from underneath the battery tray?
Maybe i cant comprehend the diagram but I'm still not to sure on what to do. Run the MBC and BOV with a t-adapter to the intake manifold? What about the charcoal line, couldn't i just cap it off?
Nothing, in those diagrams helped really. I'm running a Perrin two port boost controller, not a mbc and i have a fp non-recirculating intake also, its says to "t" into your bov, then not to which is it bc i already have done so?
You could get a catch can setup.
But still would need fitting welded to intake pipe for catch can.
You could do emissions delete
Or just get some fittings welded onto the pipe so you could hook the lines back up.
