97_4g63t
Supporting VIP
- 472
- 50
- Jun 6, 2010
carlsbad,
New Mexico
Am I just an complete idiot or is this just ####ing horrible. I wish he would have saved a log so I could show it. 91 pump gas 4th gear pulls. 27psi. 15* of knock with 0* of timing. Ummm doesn't that mean you need higher octane or to turn the boost down? That is how it was left. How many of yall have had to run through two gears on the dyno?
You can't adjust base timing on a 2g...unless you have a 1g cas.
What you can do, if you have (dsm|ecm)link, is activate the knock sensor based on user-defined parameters such as rpm and tps, which is what most DSMers do.
