Dyno day.
briank
80
Aug 13, 2006
dallas, Texas
I went to a dynocom today in fwd.
3052 @ 25psi.
Fp2 cams.
id1000cc @ 70 idc with 11.2 on 93 octane. 45 psi base pressure.
I do not like the numbers.
577whp/432tq? Seems pretty good to me. Whats the size of the comp wheel on that 3052? Especially for being on pump gas and only 25lbs
Dont know much about the 3052 but those numbers look great for 25 lbs.
Do you happen to have any logs of this (not sure what you are using to tune since your profile is empty)? Maybe some more info on your setup?
I am having a very hard time trusting this dyno.
11.2 on 93 octane.
11 degrees timing.
Stock 2g head with fp2's. Jmf with n/a tb. Spearco 216. id1000's with a wally 255. I am tuning with an aem if that matters.
I don't trust this dyno ,my dyno was 397 hp mods in profile to high for my mods
11.2 on 93 octane.
11 degrees timing.
If its accurate, and I don't believe it is, that would be the most power a 3052 has made that I've seen. I think that dynocom dynos read 15-20% higher than dynojets though. Still, around 500 on a pump gas 3052 is nothing to be upset with.
