edged1g
- 302
- 25
- Feb 23, 2005
Huntingdon Valley,
Pennsylvania
I am trying to chase down a high idle problem(among others). I got so fed up with it, I bought a smoke machine leak detector. I pumped the intake FULL of smoke(I could tell by disconnecting the PCV hose and see it pouring out) but saw NO leaks. I am stumped at this point. The BISS is all the way in and only gets the idle to about 1000-1100 rpms.
I also tried applying vacuum to the brake booster using a hand vacuum pump with the car off to see if it was a problem. I pump it up to 20in/hg and it held there strong without dropping off.
I am looking for ideas or suggestions at this point if anyone can help. I can't get the idle down!
