2G Help with turbo oil leak and a lot of smoke
Nguyen13
Jan 15, 2023
Del rio texas, Texas
Could someone help me, my turbo leaks oil from this part and it is blowing too much smoke, do you think it is because of that?
Is the turbo draining properly so that new oil can get into the CHRA? That crush washer should seal and I would tell you to try and tighten it up, but I sure don't want you to break it OFF in the housing so just make sure that fitting is as snug as you feel comfortable with. You want the brass to squish a little for it to seal.
