help with diagnosing a couple problems...
shaunmy
Feb 26, 2006
omaha, Nebraska
first off, the car is a 91 turbo FWD with 95k on the clock, and is 100% stock.
i am having an issue with shifting. sometimes its extremely hard to go into gear, sometimes it goes into gear with no problems. i have recently replaced the clutch slave and master cylinders, (there is no air in the system, so forget that option) and the clutch pedal is adjusted well. it seems like it does it more when its cold but maybe thats just me. it also does it when the car is completely warmed up sometimes. usually when it happens, it comes and goes in spurts. for instance it will be hard to shift almost the entire way to work one morning and that night it will shift awesome. the transmission fluid was replaced about 5k miles ago with pennzoil syncromesh. the clutch pedal is just as stiff every time i push it.
all i can think of is sticking synchros, or maybe something is worn in the clutch pedal assembly? like i said it is not air in the system. the shifter cable bushings look fine as well, and i would think like if the shift fork was bent it would be more of a continuous problem....
EDIT: car shifts perfectly fine with engine turned off.
the other issue i am having has to do with the car accelerating and idling. when i turn my headlights on, my motor will slow down by about 200rpm. and when i am sitting at stoplights my dash lights will become a little bit dim unless i give the car some gas. it also randomly idles either very smooth, to a little rough, to sometimes noticeably rough.
part two of that issue (i think it may be related) sometimes when i am accelerating, the car will come in and out of accelerating. it almost feels like fuel cut, but it comes in spurts. for instance, while in second gear, accelerating at about half throttle, it may cut out 3 or 4 times before i shift to 3rd gear. and if i floor it when its doing that, my car feels as slow as a honda (LOL) it almost is like im getting huge amounts of knock and the ecu is retarding timing a lot (i run 92-93 octane always) this does not happen very often though, maybe once every couple of days. and spark plugs/wires are good and new, respectively.
there are a million things i could guess for this, thats why i am asking if anybody has any experience/ideas with these issues. IAC? TPS? ECU? maf maybe? i have no idea where to begin looking.
thanks for any input,
shaun
Sounds a lot like one of the symptoms of leaking capacitors in the ECU.
The difficulty maintaining idle speed would be from a bad Idle Speed Control (ISC) motor or damage to the ISC drivers inside the ECU.
Is the check engine light on when the car hesitates?
Steve
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
