A couple of problems that I need help with.
Niteninja01
167
Nov 18, 2009
Milwaukee, Wisconsin
1. Ok to start off, I bought a t-28 of a kid checked the shaft for play and there was barley any, but I did notice some little scraps on the intake side of the inlet , but no play. So I put the turbo on and it's was fine for about two months, I go to install my mbc and I decide to check for play and there was some up and down play and that's all. How could I have killed my turbo that quick? Mind you I didn't have a boostguage at the time the turbo was installed so I had no idea that I was running 15lbs. Could this have killed it? Did I do anything wrong when I installed it?
2. I was having uncontrollable boost so I bought a mbc to keep it down to around 10lbs. I hooked it up right. I used this forum Best way to install a MBC.
And I have it all the turned out and I went for a drive and I gave it some gas and she still went up to 20lbs I let off right when I seen that. I just don't get it. Any help on any of this would be great thanks.
Yea, I turned it almost all the way out. I don't want to damage anything with boosting so much.
