List of problems i need some help with.
Radam
Feb 5, 2006
Stettler,
I've got a few problems that i don't have a clue about. Its a 1991 plymouth laser rs turbo with an 16g turbo, manual boost control, and a 3 inch down pipe, all of which where installed by the last owner. The problems are as follows:
1. after starting the engine when its cold the rpm's fluctuates when driving, but it stops after the engine warms up.
2. i have to add b/w a quarter to half a litre of oil every 100 to 200 km but this will go on for about a month then quit and use hardly any oil at all.
3. whenever i turn the wheel i can hear a squeaking from the front, i tightened the power steering belt but it didn't do anything.
4. at odd times shifting becomes alot less smooth and it grinds going into 4rth from 3rd
im fairly illiterate when it comes to cars so any help is greatly appreciated.
About your grinding gears...when does your clutch pedal engage off the floor? about 1/3 of the way up or sooner? If it engages too soon (right off the floor) then you should adjust it and hopefully that will take care of the grinding, check out the link below for adjustment. If that doesn't solve the problem it could be your syncros are bad. Changing your tranny fluid can usually help this a little bit, use gm or penzoil syncromesh, my tranny shifted a little smoother after changing the fluid.
http://mywebpages.comcast.net/njdsm2/clutch.html
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
