need some parts list help
scaryfastdsm
70
Jan 9, 2008
bonney lake, Washington
ok i live in washington and i blew my motor by spinning the timming belt so i plan on a rebuild when i get the money. about $4000 i can spend. here is what i will get. what i am asking is tell me if this set up will be safe to run 400whp safely. car is a 1991 gsx eclipse awd and has 150k on chassie.
slowboyracing stg 1 2.0l longblock race motor.
slowboyracing g50 50trim, turbo.
850cc rc injectors.
walbro 255lph fuel pump.
ugeo wideband 02, monitor air/fuel.
gauges are boost,a/f,oil pressure.
10mm sparkplug wires.
manual boost controller.
xspower 10x28x3 inch fmic w/ 2.5inch piping.
3inch hard shortram intake.
gm maf-t 3inch maft, tuning injector size and running gm maf.
3 inch race exhaust turbo back, w, tube equal lenth headers.
There are a ton of threads on people wanting 400hp. It can be achieved a combination of ways. There is no need to get a SBR longblock race motor. Just put a good set of rods/pistons in your car with some ARP hardware and a good set of springs and 272 cams in the head and you will have just as good of a motor at a fraction of the cost. If you are going to stick with an MHI housing turbo I would go with an FP race manifold instead of a tubular manifold. In the long run it will be better for everyday street use and has almost the same performance advantages. Other than that your list looks good. I would maybe go with something a little bigger than 850cc injectors and get the new version of DSMLink which will save you money on not having to get a MAFT setup. The only other thing I really see missing off your list is a good clutch setup and an AFPR.
http://www.dsmtuners.com/forums/search.php?searchid=6184801
Yes, those parts will support 400 WHP with the proper tune.
And I also agree with Adam's recommendations above.
thanks for the imput its just that no one in washington wants to build my car for very cheap and sbr said they can get me a race motor for 4gs at most for that power range. and i just put a stock replacement clutch in so i will have to run low low boost.
So are you going to shoot for 400 WHP or keep the boost low?
Are amount of decent power will burn up a stock replacement clutch in no time flat.
im want 400whp, i will be upgrading the clutch but i need to find someone to build my engine for decently cheap and i wanted apr head studs, apr rod bolts, balanced crank, crossdrilled, topline rebuild kit. stock cams
You probably already know this, but you're going to spend almost all your money on an engine build if you're going for a ready-to-drop-in motor from a vendor. If I were you I'd post in your regional forum and see if anyone is willing to lend you a hand, and that way you not only get it together for a much more reasonable cost, but you have the knowledge to hopefully do it yourself in the future. That's what I'm planning to do myself. :] Good luck on the build. - :dsm: Ryan
When the timing went, how much damage did it cause?
If it just bent a few valves, and you're bottom end wasn't tired to begin with, then you should just have the head rebuilt. A stock bottom end will hold 400 WHP just fine, so there's no definite need to have it rebuilt.
850cc rc injectors.
Not sure if anyone else caught this but, if you get a wideband you will not need a regular a/f gauge. Just mentioning that so you don't get a gauge you don't need. You could possibly get an EGT gauge if you wanted to monitor your motor some more.
Head
DKS 2 Cams - FFWD Connection - Race Injuns That Will Freeze Your Brain - $297
BC Springs and Retainers - Brian Crower Valve Spring/Retainer Kit (DSM / Evo) - Modern Automotive Performance - $218
Si Valves - SI Performance Series Valves (DSM / Evo) - Modern Automotive Performance - $195
Cometic MLS Headgasket and ARP Headstuds - $152
Block
Eagle Rods and Wiseco Pistons - Wiseco Piston and Eagle Rod Combo (2.0/2.3/2.4) - Modern Automotive Performance - $735
ACL Main and Rods Bearings - ACL Aluglide Series Main and Rod Bearings (DSM / Evo) - Modern Automotive Performance - $50
ARP Main Studs - ARP Main Studs (DSM / Evo) - Modern Automotive Performance - $58.00
Turbo
PTE SCM 5031e - PTE SCM50 Series (Mitsu Bolt-On / 450 HP) - Modern Automotive Performance $900
FP Race Manifold - Forced Performance Turbochargers: FP DSM Race Manifold - $220 with install kit
Ebay FMIC Kit - eBay Motors: Eclipse 95-99 FMIC INTERCOOLER W/UPPER&LOWER PIPING 2G (item 370162550715 end time Mar-22-09 08:49:37 PDT) - $285
Tuning
DSMLink V3 - ECMTuning, Inc. - $595
AEM Wideband - AEM Gauge-Type Wideband UEGO Controller - Modern Automotive Performance - $219
Fuel
Walbro 255lph - VR Speed Factory - EVO, DSM & WRX Performance Parts - Fuel Pumps - Walbro 255lph High Pressure Fuel Pump & Installation Kit (FWD & AWD) : 95 - 99 M - $90
FIC 850cc - Fuel Injector Clinic 850cc Injectors (DSM / Evo) - Modern Automotive Performance - $275
Aeromotive AFPR - Aeromotive Adjustable Fuel Pressure Regulator with Install Kit (DSM) - Modern Automotive Performance - $220
Misc
Rebuild Kit - Fel-Pro Lower Block Gasket Set 6 bolt DSM - Modern Automotive Performance - $75
Intake Pipe - DEJON | Powerhouse - $115
Turbo Install Kit - Oil Feedline Kit (Oil Filter Location) - Modern Automotive Performance - $40
Oil Pump - Safety Oil Pump - Modern Automotive Performance - $150
BSEK - Balance Shaft Elimination Kit (DSM/Evo) - Modern Automotive Performance - $25
Timing Belt Kit - Complete DSM Timing Belt Replacement Kit - Modern Automotive Performance - $220
Waterpump - Topline Water Pump DSM - Modern Automotive Performance - $52
Fidanza 4.3 Clutch Kit - Fidanza 4.3 Ceramic Clutch Kit (DSM) - Modern Automotive Performance - $355
Now without even shopping around at all I have completely built your setup for around $5500 with a built bottomend, all your supporting mods and a clutch even. The Slowboy stage 1 longblock will run your over $5000 alone shipped. Not to mention it comes with stock rods, cams, springs and a whole other onslaught of stock parts. Take the time to research the parts and do it yourself and you can save a TON of cash.
