Newbie, parts list help.
Status
Not open for further replies.
rb97GSX
Jun 28, 2006
Ames, Iowa
Hi, I'm kinda new to DSM's so stay with me for the first post. Can you guys help look over my mod list? Please tell me if you think I need to add or take out anything. I'm keeping it pretty stock, So here it is...
Thanks you.:dsm:
- Apexi N1 exhaust
- Apexi N1 downpipe
- Greddy Type-S BOV
- K&N FIPK Air Filter Kit
- Injen Intake Pipe
- Auto meter boost gauge + single pod
- Joe P manual Boost Controller
- Walbro 190lph Fuel Pump
- A'PEXi Super Ground System (Ground Wire + Voltage Control)
- Greddy Full Auto Turbo Timer
Drop the profec b and get a manuel boost controller. and if you dont have strick emissions laws then drop the cat and run catless, and with that money saved get yourself a 16g turbo to start with if thats all your funds for now.
Like I said I'm new, won't I need some more supporting mods to go with a 16g turbo? BTW: Is the list good as is and will I need the fuel pump for what I have down there, if I upgrade turbo's it will be a lot later.
O, and also, my fault. The Apexi down pipe deletes the CAT so I'm good there.
The fuel pump is needed so that you can push the boost without leaning out. You could get the 16g down the road and just have one less thing to worry about if you have already done the fuel pump.
Running a 190 fuel pump you will be fine with a 16g. Also if you dont plan to have a FMIC soon or ever, then just like stated above get some hard intercoole pipes.
Beat me to it.
Thanks, I'll also switch to a Joe P manual boost controller, I hear good things about it, unless u guys can think of a better one? And will I need the fuel pump for the set up I got listed, basically before I upgrade the turbo?, it will probably be awhile before I do.
nm about the fuel pump, wow you guys type fast!
Also, will the 16g bolt right up or should I get a better manifold?
Thanks you.:dsm:
- Apexi N1 exhaust
- Apexi N1 downpipe
- Greddy Type-S BOV
- Injen Intake Pipe
From one newbie to another...so far an excellent start. I would upgrade the intercooler piping as someone stated earlier, do the bcs mod if not done, but the manual boost controller should help. Also a 1g throttle body should be good for a few ponies also.
OK a few questions,
1- which is the better turbo timer, Greddy or Apexi ?
2- "do the bcs mod if not done" Whats that?
3- the slowboy racing link didn't work so I'm guessing it was a install package, AMS also has one, is that one good as well?
4- Does the 1g throttle body just swap right in? and can I add it before the turbo?
Thanks
Really, I'd probably upgrade to the manifold after turbo but throttle body before. Can anyone help with my questions above?
Read the rules, then figure out why your thread was locked.
Status
