Need help on my parts list
I DSM KILLA I
120
Jan 11, 2009
Bensalem, Pennsylvania
Okay I am finished but need some feedback. Any suggestions are much appreciated!!
Thanks!!
Eclipse Parts List
Maintenance
Engine Rebuild Kit
• Replace all gaskets, bolts, and other etc
Gates Timing Belt Kit
• Includes timing belt, accessory belt, and all pulleys
Gates Water Pump
• OEM Replacement Water Pump
Jack’s Trans Rebuild ‘Kit B’ Value
• Rebuild/upgrade kit with 4 spider
Jack’s Trans EVOIII Kit
• EVOIII Conversion Kit
All new OEM Suspension
• Control arms, lateral arms, and nuts & bolts
Front and Rear Axles
• New OEM replacement axles
Wheel Hub Assembly- Front
• Front wheel assembly
Wheel Hub Assembly- Rear
• Rear wheel Assembly
Beck/Arnley Front Calipers
• Front fully loaded calipers
Beck/Arnley Rear Calipers
• Rear semi loaded calipers
Brake Rotors & Pads
Beck/Arnley Clutch Master Cylinder
• OEM Replacement Clutch Master Cylinder
Beck/Arnley Brake Master Cylinder
• OEM Replacement Brake Master Cylinder
ACT Xtreme 2600 + Streetlite Flywheel
• ACT Xtreme 2600 Clutch Kit & ACT Streetlite Flywheel
Walbro 255 HP Fuel Pump
• Includes install kit
FIC 1100CC Hi-Z Injectors
• Saturated/High Impedence Ball & Seat Injectors
Brian Crowler 272/272 Camshafts
• Includes intake and exhaust camshafts
Brian Crowler Adjustable Cam Gears
• Includes both gears
Brian Crower SS Intake Valves
• Stainless Steel Intake Valves
Brian Crower SS Exhaust Valves
• Stainless Steel Exhaust Valves
Brian Crower Valve Spring & Retainer Kit
• Chrome silicone alloy springs & titanium retainers
Eagle H-Beam Connecting Rods
• ESP H-Beam Connecting Rods 5.900” Length
Wiseco Extreme Duty Forged Pistons
• 88mm Stroke, 8.5:1 CR, 5.905” Length
Eagle Forged Chromoly Crankshaft
• Forged steel crankshaft, 88mm Stroke
Mitsubishi TD05 EVOIII Big 16G
• MHI EVOIII Big 16G supports 380HP
TiAL QR Blowoff Valve
• TiAL 50mm Blowoff/Bypass Valve
Dejon Powerhouse FMIC Kit
• Front mount intercooler kit with short route piping
Dejon Powerhouse Intake Pipe
• Intake pipe to replace stock
Forge Motorsports UNOS Boost Controller
• Manual boost controller
Exterior
New hatch
New headlights & foglights
New wheels & tires
Interior
Full black leather interior
Pioneer FH-P8000BT Double DIN CD Receiver
• FH-P8000BT CD Receiver with Bluetooth and iPod Connect
Infinity Kappa Five 5-channel Amplifier
• 4 x 50W RMS @ 4 ohms, 1 x 350W RMS @ 2 ohms
Infinity Kappa Perfect 6.1 Component System
• 6 ½” Component System with 1” Tweeters and external crossover
Infinity Kappa Perfect 5.1 Component System
• 5 ¼” Component System with 1” Tweeters and external crossover
Infinity Kappa Perfect 10.1 DVQ Subwoofer
• 10” Die cast subwoofer
I don't see a fuel pressure regulator for the Walbro, or a fuel pimp re-wire kit. What are you going to do for tuning? Gauges and wideband? I also didnt see any exhaust components, manifold, O2 housing, downpipe, catback. Are you trying to do this all at once, if so that's like a 7 grand list or greater... Is this just your wish list?
I realized after I posted that I didn't post an exhaust. I am going with an Apex i World Sport 2. I also didn't list Ecuflash and as far as I know, the install kit has the rewire kit. This list was the "Main parts" and I know there may be some nuts and bolts missing. And yes well over $7000. I am doing it over a 6 month period while the car gets stripped and repainted. I am also putting Dynaspray for sound deadening. The gauges are "undecided" and I am not at all sure of the fuel pressure regulator.
My goal is to rebuild to stock specs, then add on the performance to achieve between 350-400 HP.
Install kit and re-wire are not the same thing, and I haven't seen a Walbro for sale that has an install kit and re-wire.
Expensive choice on the catback...good luck!
Run DSM Link or an AEM EMS and with the list you have there trying to get 400 whp would be easier to do with a 20G in stead of that 16g. Buy a fuel pressure regulator because you WILL need one and at least get a boost gauge and oil pressure gauge. Does that list include a new oil pump? what about a SS clutch line? those SS clutch lines really are nice (i use one) especially with ACT clutches due to the fact that they are known to have engagement issues!
I'd throw an AEM wideband and DSMlink in the mix there, along with thinking about a 20g, or hybrid 20g like the fpgreen. You're buying the injectors to support it, and once you hit 350-400 hp, you're gonna want more... at least that's what I've heard from (almost) every corner of the DSM universe
Not me. I just want a reliable :pray: but a little faster DSM. I was actually secondguessing buying injectors that big. And that cat back is the quietest from what I have heard.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
