1G Help Warning lights
Topcarparts
31
Aug 27, 2019
Manila, Asia
I dont know what this light means...
Have and check engine
The other warning light i havent any idea..pls help dsmers
If you mean the led that's in the round plastic punch out, that's an led for a security system possibly. Does it come on at any times?
Otherwise I can see what I believe is the radiator light, which means your low on coolant, as far as the radiator overflow bottle is concerned. Check the overflow and make sure it's not dry, and also make sure your not low on coolant under the thermostat housing rad cap.
Have you pulled the codes for the check engine light yet?
Not sure what the far right light is, I believe it's a brake warning light, indicating low fluid or an abs fault possibly?
Henry, the Red led is just a dummy. There is nothing at all behind my 92's. I kinda figured there would be wires or something, but nope, nothin.
Could the combination of lights be the alternator or alternator fuse maybe?
I assumed topcarparts was referring to all of the dash Christmas lights......:)
So far i havent scan the check engine issue..
The other side of warning light is normal.. its handbreak light which i pulled coz its on park.
But the 2 lights is my concern.. maybe coolant is low.
I notice my coolant sensor switch/fan switch is broken.
Just bought this gen1 dsm
The fan is directed=if u run the car u need to directly put the wire of the fan to positive terminal of the battery
In the bottom tank of your radiator (on a 1g), near the bottom hose outlet, there should be a 2 prong sensor. It makes a connection at somewhere around 185*F to ground your cooling fan, making it turn on when it is needed. Does your radiator have that sensor? If so, it should be used to make the fan come on. The fan relay is always 12v+ and waiting on the sensor in the radiator to throw a ground, which makes the fan come on.
Need help..
Problem
No radio power
No ac power
No power on window switch
I think this is bcoz i.o.d fuse problem.but when i check my fuse box.the i.o.d fuse SL is MISSING no more.. so i dont have any idea what it looks like.. anybody has the picture of this fuse?
