Harness Re-construction, removing unneccessary wires
tkstoygsx
190
Dec 9, 2007
Green Valley, Illinois
I am in the process of cleaning up my engine harness for a wire tuck and have run across a few wires that I would like to remove all together without any adverse reaction . I am unsure if this will be ok or not so this leads to my thread asking for fellow members thoughts. I was thinking it would be ok to leave the below mentioned out since I no longer use any of the sensors themselves. Could some of you please leave your feedback so that I can get this part of my project finished up!
(numbers correspond with PIN Location per vfaq.com) and these are being removed @ the ECU.
3 - Turbo Gauge
5 - Power Steering Oil pressure switch
7 - Air Conditioner Switch
11 - ABS control unit
15 - EGR Temperature Sensor
53 - EGR Control Solenoid Valve
57 - Fuel pressure Control Valve
62 - Purge Control Solenoid Valve
65 - Air Conditiong Relay
105 - WasteGate Solenoid Valve
Thanks,
Travis
Been there, done that! :LOL:
I had no ill effects removing those. But I'm also running AEM EMS, so not sure if that had anything to do with it.
