Two spare wires in engine wiring harness and SD question?
crash89
3,543
195
Mar 5, 2008
Punta Gorda, Florida
Hey fellas, so heres the deal. Some of you may have seen my build thread and know that I cut the wiring harness in half so I could route my harness how I wanted for a good tuck. I labeled ever wire with appropriate numbers and cut between the tabs, so each wire had the same number on both ends of the harness. Well now I have all the wires soldered back together aside from two. One wire is Blue w/ red stripe and goes to the coil pack plug, other is Black w/ white stripe and goes to the power transistor plug. Does anyone know where the ends of these wires are supposed to go? I dont have any more wires available to be tapped into or labeled with their respectable number.
471526[/ATTACH]"]
Blue w/ red stripe
471528[/ATTACH]"]
Black w/ white stripe on left.
471530[/ATTACH]"]
Now, the Speed Density question. I read Gofers write up in wiring in the GM IAT sensor http://www.dsmtuners.com/forums/articles-electrical-wiring/377567-wiring-logging-gm-iat-sensor.html, and I see which wires I need. Now, I dont need any of the other 5 wires in the maf plug do I? So once I run those two wires for the IAT sensor I can delete the other 5, correct?? Thanks guys!
