hard to (cold) start with low RPM
nwbDSM
63
Feb 15, 2011
Boalsburg, Pennsylvania
First off, I did search and could not seem to find the same issue that I have. I recently installed FMIC, AFPR, and 720cc FI. I remember that the first time when I fired it up, it started right up and stay in high RPM (which I think it's normal for cold start). Then, I got everything tuned with DSMLink 2.5 and it was running fine.
Then the next day, I tried to start a car and it would take me like 4-6 cranks before it fired up (temperature ~50F). It would start up fine after the engine is warmed up. But everytime, when I leave a car for awhile, it would take so many cranks (with a little bit of tap on the gas pedal) before I could it to fire up. What I found though, when it first starts up, the RPM would not go up as it did in the past. It only stays at the idle RPM (750).
So, I don't know if this has something to do with the thing (don't know what to call) that helps keep RPM high during the cold start. I feel like there is nothing to compensate the engine to fire up.
Any idea what could cause this or the steps I should take to troubleshoot it.
Thanks.
The FIAV in the throttle body could cause this if its not opening. I recently deleted mine due a continuing idle surge but now it starts a little rough and will barely idle without it. Once it warms up as you mentioned it runs great.
Just my .02 cents
Just my .02 cents
That sounds exactly like what I'm experiencing. I have to play with the gas pedal to keep it idle. Is there anyway to check if it goes bad?
I have the same problem! If I touch the accelerator before letting it sit and warm up, it dies immediately. Does your car do that too?? I read somewhere that its a problem with the coolant temperature sensor?
