shifty2006
- 145
- 5
- Oct 15, 2012
lake isabella,
California
95 gst I bought the car from an owner that didn't know much about it just said it had a 98 motor. The car had one axle in the back seat and the other one was in it so I purchased an axle from napa put it in spun the tires while it was jacked up and the driver side axle just slopped around in the trans the shaft was too skinny for the trans so I had to replace it too. When it was done I drive it but there is a loud grinding sound like metal on metal but its not like brake grinding. I jack the vehicle up off the ground I can put it in gear and run it through the gears with no grinding but once it's on the ground it grinds. I've tried to read all the post about the axles and splines on these but the only s/n on the trans I can find is f5m31 no other numbers. The motor has 4g63 with 1w6138 under it on the block by the turbo. While looking at it i see it has a new slave cyl ad i can look in the bottom if the bell housing and see a part of a new clutch assembly The car is lowered fmic, mbc, turbo timer, boost vac gauge, I'm at a loss the motor runs great
