SeriozHenka
- 8
- Mar 30, 2023
Watertown,
Wisconsin
I just picked up a 1990 Eagle Talon TSI AWD and I have been noticing a slight grinding when I shift into second too fast and also it popping out of second and reverse if I shift too quickly.
I can completely avoid the grinding if I hold the clutch down, and pull it into second as hard as I can and then let go, but if I shift like i would in any other gear it will grind just for a second and then find its way into gear. Sometimes if I don't pull it into 2nd as hard as I can it will pop out of second, making me have to put it back into second, and then it doesn't grind. Reverse doesnt grind, but if I don't put it into gear as hard as I can it will slip out back into neutral.
Both these gears once they are in work perfectly fine, they only pop out right after I shift into them, that could just be me not pushing it hard enough each time. I can avoid the grinding completely as long as I take my time shifting from first to second and don't beat on it.
The car has 85k miles and I don't believe has ever had a trans flush, which I will be doing soon. I'm pretty sure it's synchros, but I really hope it isn't because synchros are expensive to fix, so, if it's anything else, what do you guys think it could be? Thank you.
