Gauge wiring help needed
Tiki2777
1,104
147
Oct 9, 2011
Omaha, Nebraska
I got new sweet glowshift gauges, but i need some help with wiring. They came with a nice wiring harness to make everything easier, but where are some spots for the wiring in the car such as:
Constant 12 volt source (+)
Switched 12 volt source (+)
Vehicle Ground (-)
Switched 12 volt Headlamp source (+)
Thanks ahead of time for the help.
What glowshift gauge(s) did you get?I installed mine on the drivers kick panel you will see a fuse box, and that it where I tapped mine into.
i tap mine from the radio harness. your gauges will turn on with the key on the first click.
boost; volt; and coolant/water temp
I had a few issues with the senders and glowshift gauges not functioning fully till about a week of them running, you may run into that issue.Sorry I can't fully diagram how to connect the wiring its been a while sence I have done it and don't want to set it up wrong for you.
I've been testing these suckers with 9-volt batteries :D they work
Personally i don't use my cigarette lighter very often so i tap into those wires from behind the center console. If my gauges ever stop working i would know exactly where to look and it would be easily accessible. If something should ever burn or stop working at the end of the day its JUST my cigarette lighter.
