Gauge cluster issues. (1g)
Qolat
Jul 22, 2004
Under my car, Washington
Ok, temp, gas level gauges on my car accasionally decide to max themselves out, turn signal indicators in the gauge cluster won't work when this is happening (but the signals still work), and accasionally the oil pressure gauge will peg itself (it's disconnected so should'nt read anything) This tends to happen after I launch hard and get wheelhop, and then it'll manifest itself for a few days/weeks then it will randomly go away as suddenly as it started.
Any thoughts on what could cause those gauges to randomly wack out the oil pressure gauge is definently a different problem than the other gauges/turn signal indicators.
T
also have taken the gauge cluster out and wiggled everything around and it did'nt make any difference. is there like a plug that might be lose or sumthing that someone has found before?
T
