Fuel Tank / Pump Check Valve?
tsi1991awd
1,366
6
Sep 28, 2008
Puyallup, Washington
I was wondering if anyone had a part number for the check valve that sits on top of the fuel tank...it is right next to the fuel pump cover that you unbolt when pulling the fuel pump.
I have some plastic check valves that I bought...using it in the PCV and Brake Booster, but I'm not sure if it can be used to replace the check valve at the fuel tank....anybody know?
I wouldn't use one of those usplastic check valves that you are using for blocking air. That will cause a major restriction in your fuel line and there is no guarantee it will hold up to gasoline or alcohol. Look on ebay, there are special check valves for fluids and fuel.
If there is one, it would be in the pump itself and from what I'm gathering is our systems use an oring to keep the pressure in.
I'm dealing with a loss of fuel pressure as well.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
