fuel management questions.
spawn87
908
3
Dec 6, 2007
sacramento, California
im putting in a ported 14b into my car and ive already rewired my fuel pump. for now i plan to keep it at 15psi...but when i get it tuned i want it at 18psi so i know ill need 550cc injectors... my questions are:
do i have to get a 255 pump?
and is a fpr really needed cause chop that is going to tune it said i wont once its tuned.
thanx
A 255 is not required. But if you do get a 255 then yes you will need a FPR as a 255 will overrun your stock FPR. You could get a stock evo 7 or 8 pump, they are good for about 190, you could get a 190 Walbro, you could get a 3000gt or Supra pump. Many options. You could upgrade the entire fuel delivery system and keep your stock pump as was done here:
SteveTek Labs Research: High Flow Fuel Delivery System
Depends on your future goals and how cash you have on hand to put into upgrading your fuel system. Either way I would read that write up as there is very good information in it.
In other words when you use a 255 with stock fuel pressure regulater ## fuel pressure will increase to probable 55psi. But if your tunning it u shouldn't have a problem i ran my car the same way with a tune n never had a fuel issue it usually run's pretty rich if you dont tune it.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
