- Year
- 1995
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- E3B16G (ported) w/ss o2 housing. @16psi
stock injectors
front/back megan tower braces.
injen cold air intake.
home-made metal shifter buchings
SSAC fmic.
greddy type s bov
3inch tsudo down pipe/ high flow cat.
3inch thermal r&d cat back
battery relocated to back.
aeromotive fpr.
walbro 255lph
aluminum radiator.
- Mods-Engine
- 2g head:272 delta regrinds/ manley springs and valve assembly, AEM truetime adj cam gears.
1g 6bolt block: evo9 pistons/ graveyard motorsport rings (.020 over) 1g big rods and crank
b/s removed.
- Mods-EMS & Logging
- boost/vacuum gauge.
rewired fuel pump
ECM LINK V3 LITE
electrical oil pressure gauge.
lc-1 WB
- Mods-Drivetrain
- COMPETITION CLUTCH STG4 sprung clutch kit w/ACT lighten flywheel.
transmission shifter bushings.
vr4/cobra BBK
- Mods-Handling
- 18 inch tsw wheels with toyo proxy4 z-rated
full tein ss kit
rear camber kit
- Parts Wishlist
- sway bars
50 trim.
