2G Fuel issues - no start, possible bad fuel pump?
Ashton3D
31
3
Jul 21, 2022
Regina, SK, Canada
I had a theory that adjusting the fuel pressure regulator and trying to start may tell me if it's either the fuel pump bad, or the fuel pressure regulator bad. Adjusting the fuel pressure regulator did not help at all though so I decided to try something else.
What is the fuel pressure output when using the test terminal for the fuel pump?
I decided I'd try to adjust the FPR and then try the test terminal, the results didn't change.
Right when my dad used the test terminal I heard the fuel pump running, then after it took a few seconds and the pump climbed at a mild pace to .5 BAR (~7 psi). I'm not sure if this proves that the fuel pump is weak or if that's all the test terminal puts out.
When trying to start the fuel pressure doesn't climb at all, it stays at zero. It may climb if we kept cranking it for longer but we didn't this time, last time it didn't start no matter how much we cranked it and nothing has changed past me cleaning the FPR.
So, summary. What's the normal pressure from the fuel pump test terminal, and does it mean anything that mine only went to .5 BAR and it took a while to reach there? Is this the sign of a bad fuel pump?
Solution
It's a Walbro but it's been sitting in fuel for a long time. It was brand new before sitting but I feel it could've gone bad.
I have pulled it a few times, no obvious issues. I had to pull to drain old gas and to replace filter and visually inspect.
Attached is an image of the old filter sock. Guessing it's not a good sign, the internal are probably clogged or something...
I see no reason why the gauge would've gone bad, I doubt it. It's a Greddy gauge but was also new before sitting and it does function so.
If it's been sitting for years now I say yes the pump is likely bad. Or more correctly gunked up from old gas and there is no saving it.
Same as when the car runs.
It does does not prove anything.
Not necessarily. Could just be a leak at the pump inside the tank. This seems very indicative the problem is in the tank.
Is there a gasket or something in the tank (on the fuel sending unit?) that would've likely gone bad after sitting in gas for ~20 years?
Remove the pump and inspect. If not evident issues are found replace it they are under $150.
Idk what “test port” you speak of but if its a fuel pressure test port on the rail then you should be reading way more then 7 pounds. They idle at 43. My car builds 40 while cranking.
It's E on this diagram. The official name is "Fuel pump check terminal" you power it with 12v and it activates the fuel pump.
Yea so you are running the pump at all times so ya your pressure is low. Or your gauge is bad. Pull the pump. If it is aftermarket then they are installed to the pump hangar with a rubber section of hose that can split with age. If its original pump replace it consider it an upgrade.
Solution
Be sure the o ring is seated correctly in the fuel pump hanger. Make sure the fuel pump is fastened correctly and firmly.
Change the filter in the bay if you have not already. It’s a lot easier to test the fuel pump with ecmlink than using the check connector too IMO.
-Daniel
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
