2G Fuel injectors
But so will a million other things, gotta take em down 1 by 1 though
Wow that thread is perfect I'll be following up on that checklist for sure! Also, there is a boost controller im not sure how to set it but it's at a low boost and I'm not sure if the ECU has been upgraded or anything might need a tune
Like Chump said boost leak, you live here in Indiana, it's been hella cold lately, and the silicone/rubbers holding our pipes together get hard and tend to leak or pop off.
If you are having problems and it's low boost, when you turn it up, you will blow the pipe off or the problems will be more evident.
Any pictures of this boost controller?
Just look at it, clockwise should make the spring tighter and turn boost up (like a volume or most other types of knobs, which is logical), but there should be some kind of marking on it somewhere.
Pulling injector clips wont do you much but show you that cylinder misfires. That being said WHAT I do if I suspect a injector is failing is swap injectors around.
Lets say cylinder #1 is misfiring. Ill remove fuel rail, swap injector #1 with Injector # 234?
If cylinder # 1 no longer misfires, you have a bad injector. if the cylinder still misfires you have other issues.
Such as
bad coil,spark plug,spark plug wire, compression, bent valve, oil ontop of plug dude to tube seal failure.
Newbie question how do you find out what cc your injectors are? Friend just bought a DSM and isn't sure what he's running.
