Fuel filter causing fp decrease?
A couple of stupid questions since your question is rather vague....
1. Did this just happen over time?
2. At some point after the mentioned install, was the FP at 37-38PSI with the hose OFF?
3. What vacuum are you running at idle?
If you are running 37-38PSI with the hose OFF, once you put the hose back on the FP will decrease 1PSI for every 2inHg (roughly). So if you are running roughly 16-18inHg at idle then with the hose on you should see roughly 29-30PSI with the hose ON.
