vac decrease
gstnate
30
Apr 11, 2011
clovis, California
I recently installed a newer T25 on my gst. When I had my other Turbo on my vacuum stayed around 15 HG. After the swap it still ran at about 15. But recently my vacuum has decreased to 10 HG or less. So what could be the cause of this. Is it anything I should worry about?
the common place to leak vacuum is around the intake gasket, throttle body gasket, the egr valve. Also check all vacuum connections because it sounds like even before you switched your turbo you had a problem. The good vacuum zone is between 18 and 22 psi.
also check the o rings around your injectors where they go into the head
OK so ill go ahead and find a leak tester and go from there. Thanks guys
Just so you know you can make your own.
Make your own from hardware store plumbing.
You just need a rubber coupler that will fit around the inlet of your compressor. Then, cap off the other end and install a schrader valve in the cap. And you have a boost leak tester that costed less than $10 to make.
How To: Boost leak tester for $5.02 - evolutionm.net
IC Pipe Tester
