fuel filter
spritian
78
Mar 14, 2011
Murrieta, California
OMG helppp
i got the old one off, and im trying to put the new one on but there is no way that bottom 14mm bolt on the fuel is grabbing the in side of the fuel filter! ive been trying for the past 4 hours and can't even to get it to grab wether its mounted to the firewall or im just trying to spin it!!
I tried a bolt the same size, the flare nut on thefuel line is fine, and so are the theads on the new fuel filter...
any advice or tips? pleaaaase
dont know the brand, just typical one from autozone. the thing is i can't even get the old filter back on either but like i said the flare nut and bolts are fine.. do i need to push it all te way down ad then come up with the flare nut or start the flare nut as soon as i line it up?
Try leaving all mounting bolts off. It's easier to catch it when everything is loose and than tighten it all once everything is threading smoothly.
The autozone filter was so cheap and flimsy. I actually bent the new one while installing it. :garbage:
Also, make sure your pushing up on the nut itself and not the fuel line as the flare will bottom out first and not allow the threads to meet.
