Street Build Smog Legal Build
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Turbo Type
50-trim
Drivetrain
AWD
Build Type
  1. Street
Punishment Racing FMIC Kit
Tial Q BOV
Remanufactured/bored throttle body
Evo 3 Exhaust Manifold Ported/Polished by myself(Ceramic Coated)
Evo 3 O2 Housing Ported/Polished by myself (Ceramic Coated)
Evo 2 Intake Manifold w/ ported matched 2G TB
FP 4 inch Intake Tube
FP Red JB Ported (Ceramic Coated)
Apexi N1 3 inch exhaust
RRE Evo flanged Downpipe
FIC 1650cc Injectors (newest version)
Dual Manual Boost Controller (91 oct) & (E-85)
Walbro 450HP Fuel Pump Re-Wired
Mishimoto X-Line Radiator
2 Mishimoto 12 inch Slim Fans
Polyurethane Motor mount Inserts (Left & Right)
Billet Front and Rear Motor Mounts
K&N FIPK Air Filter
Mishimoto Oil Catch Can
Alternator Wire Upgrade to 4 Gauge
Saturn 200 Amp Alternator w/ Mitsubishi Voltage Regulator (From MotorCityReman)
Fuel Lab AFPR Kit
Fuel Lab Fuel Filter Kit
Mods-Engine
2G Head
GSC Zero Tick Lifters
Arp L19 Head Studs
FP2 Cam Shafts
Kiggly Beehive Valve Springs & Retainers
Supertech Black Nitrided Intake Valves (STD)
Supertech Inconel Exhaust Valves (STD)
Supertech Bronze Valve Guides
6 Bolt Block
Manley H-Beam Rods
7Bolt Wiseco Pistons
O-Ringed by TedSpec
Assembled by TedSpec
Kiggly Mod on Oil Strainer Fab'd by TedSpec
ACL Tri-Metal Race/Main Bearings
Balance Shaft Elimination Kit
Kiggly Racing HLA
Mods-EMS & Logging
ECM Link V3 Full
PLX DM-6 GEN 3 Wide band
Autometer -30vac-45psi Boost Gauge
Flex Fuel Sensor
Speed Density
NLTS Kit installed
Kiggly Racing Crank Trigger Kit
PiLink
Mods-Drivetrain
ACT Lightweight Flywheel
Southbend SSX Clutch Kit w/ Segmented Ceramic Clutch Disc
Transmission Rebuilt by TMZ Performance
Stock Shifter w/ stiffener plate mod
ExtremePSI Shifter Bushings/Bearings
Feal 441 Coil Overs
RM Sway Bars
Evo 8/9 Brembo Brake Upgrade (Front & Rear) w/ JDM Galant Knuckles (Front only)
Stop Tech Drilled Rotors
Green Stuff Brake Pads
SPC Rear Camber Kit
5zigen FN01R-C Wheels
VMC Front Lower Control Arms
VMC Rear Toe Arms
FIBA Rear Lower Lateral Arms
FIBA Rear Trailing Arms
FIBA Front Upper Control Arms
FIBA Rear Upper Control Arms
Compworks Fender Braces
3G Brake Booster
3G Brake Master Cylinder
Quaife/EMW Evo 8 Ratio Depowered Rack & Pinion
Nissan EPS Kit
Parts Wishlist
Roll Bar
Background
Bought the car Summer 2012 from the original owner. Very Stock but not running, clean title. The car had been garaged for 5+ years. The problem it had been having was when the key was turned to the on position the ignition fuse would blow. After weeks of having it my friend found that it was grounding itself out to the chassis. Since that day I performed all maintenance and set off a fogger in the car because it had been garaged for so long there had been webs everywhere my fear was spiders everywhere when I drove it. Plans were to make it a 300 hp street car/daily driver so reliability was definitely a must. Goals are to run in the 12's for a 1/4 mile with full weight. So far everything has been accomplished just need to run in the 12's and I'll be satisfied with this build ....for now ;) update 12/9/15 the 12's were achieved with the old setup on October of 2014 The new setup is listed with full weight and the quest for 11's now but with the super stock visuals. Or at least Stock looking as can be and pass smog. Got to love California Laws. Update 4/23/16, the 11 second pass was achieved and the smog legal part is good to go but would just need to put a catalytic converter on. Goal now. Make it look clean and unique also upgrade engine Internals. Update 1/28/17 Engine blew maybe 2 weeks after I got it running last year so went with a 6 bolt swap with some tasteful upgrades. This wasn't an all out build more like on a budget. Also sourced out some rare parts while the dsm has been down like the galant knuckles for the brembo upgrade, JDM Tail Lights, not EDM. Tring to do everything as proper as I can without jeopardizing the main goal for the car which is 11 second 1/4 mile, and CA Smog Legal, just trying to maintain the power I had with the engine upgrade and keep it Tasteful
1/8 Mile E/T
7.753
1/8 Mile MPH
95.98
Timeslip Details
Full Weight
27psi
E85
No Nitrous
Street Tires
Famoso Raceway
Dyno HP
401 whp
403 lb/ft
Dyno Type
Mustang Dyno
Dyno Shop Name
Speed Element
josh408
Rating
5.00 star(s) 2 ratings
More in 2G DSM
Share this Vehicle
