Fuel filter
brandonclum
136
May 20, 2009
spokane, Washington
Hey guys just a quick dumb question here about a aftermarket fuel filter. So my fuel filter need changed and was thinking about just going with a universal clear fuel filter from Autozone can i do this or does the fuel system need some sort of back pressure the stock filter has. Im pretty sure I know the answer but just thought I would ask before i cut the stock banjo fitting off?:confused: O its a 1g auto fwd.
Guys I was asking if I can go inline fuel filter like a clear universal one the stock one that I can get they have to order it and its like 4 days out and I need the car tomorrow. So can i run one of those or no?
Those plastic inline filters aren't meant for fuel injection. Even the "performance" versions have a max pressure of 10psi. If you found a universal inline filter capable of handling the pressure, it would still be nowhere near as good as the OEM filter.
Not worth hacking up the fuel lines.
This^
Those are filters you run on your lawnmower/dirtbike.
Extremepsi sells oem filters for $20. How much cheaper do you need?
http://www.extremepsi.com/store/home.php?cat=879
or upgrade to a "818" kit
http://www.extremepsi.com/store/product.php?productid=21516&cat=1559&page=1
Some of you didnt read the post. Op said he needed it today. That being said it was pointed out local oreilley has it in stock. I dont see the problem. Clear filter in addition to not being rated for efi pressures its clamped onto the line. Use a proper filter with proper fittings. the easiest quickest solution is a stock style filter. I dont know why you would consider any other option.
There is nothing special you would need to do.
While you wait for the filter to come in pick-up the right tool to break that line loose under the fuel filter, you'll want to get a 14mm flare fitting wrench. Most just use a 14mm crescent and round the flare fitting, then resort to a pair of vise-grips and REALLY destroy the flare fitting.
Getting the right tool can turn a 2 hour fuel filter install into a quick 30min swap.
Performance Tool - Flare Nut Wrench Set
:dsm:
:dsm:
Amen!! It can be an absolute bi*** breaking off a fuel filter on a dsm,especially a 1g that has a filter that hasnt been touched in 20+ years. Sadly enough most people that own these cars never swap out the fuel filter. The last two dsm's ive had have been 1990 1g's,and it was a major pain in the ass breaking them loose. I run E85 at 400whp or so and i change my filters pretty regularily since E tends to clean out all the gunk in your fuel system. Ive been running stock fuel filters and fuel lines for almost 3 years on E85 with no issues,so im sure you will be ok running a stock filter for now. Although if you plan on going for high hp in the future,it wont hurt to upgrade now. I know thats my next step on my dsm,the fuel system. And as you can see by the links provided,its not exactly expensive.
