@TDC
- 455
- 13
- Sep 10, 2012
Nor-Cal,
California
Hey guys. I need a little help fixing my fuel feed line. The bolt on my fuel filter was stripped. So I decided to cut my fuel line because I figured I'd grab a new line. After a trip to mu local junkyard. I found a Fuel feed line, but I couldn't remove the entire hard line because of the way that it was routed. So I ended up just cutting a section that I needed. My question is there some kind of fittings or something that I can use to reconnect the cut hardlines? I posted some pictures below so you can better see what I'm talking about. Thanks for the help guys.
