FP Manifold heat shield
KGB Pilot125
486
Oct 20, 2002
Centennial, Colorado
Anyone try to make a stock heat shield with the FP manifold? I think it might work with a riser bracket and some creativity. I have 2 of them here at home and might try to work on it this weekend. If anyone has tried it do you have pictures or ideas?
JM Fabrications made a heat shield for the FP manifold. Unfortunately they don't make them anymore, but you can find some floating around For Sale threads.
had one and sold it. It didnt have a decent mount design and it would always come loose and rattle. Also I am not a big fan of BLING. I also love the idea of a little stealth.
I'm having mild steel brackets made for my FP manifold. I plan to tap the rear bracket with 1/4-20 thread, put 6" studs or bolts on it from the back and then put acorn nuts in the front.
As for not having bling, have it ceramic coated in black.
Inconel wrap top to bottom...$650 just for the manifold!!!
Imports
Turbo
TURBOGALLERY
The material chosen (Inconel foil) is a super alloy that wont deteriorate when placed very close to stuff that gets way too hot.
To my eyes, the pros are:
1. light weight compared to welded stainless shields.
2. Very complete: very few spots left bare.
3. No reason why it shouldn't last forever.
4. Barely takes up more space than header wrap.
Cons:
1. BIG fraggin' bucks!
2. many times it will cover bolts you might need to get just to assemble your new parts.
I contacted that company and the quote for the exhaust manifold was $395. They ignored my question on whether or not they had kept a "mold" of some sort after producing yours. Any idea why yours was so much more expensive?
$650 for that!? You could have done it cheaper yourself. I'd rather send it off to get Swaintech coated which looks better and cheaper.
The turbo, however, looks pretty nice. How well does it block the heat away and can you hold your hand on the shield after doing hard pulls?
I wonder if it'd be possible to modify an evo heat shield (since they have longer runners) or even the oem evo heat shield to fit. I think I remember seeing someone modify the oem evo heat shield on this forum before. The one below is only $25 on ebay.
    • Sdcryan1
