RipperXX
- 5,786
- 172
- Feb 23, 2003
Royston,
Georgia
Reduced IAT about 30*F...at least until it heat soaks after half an hour. Then only about 11*F above ambient while moving..its aluminum. Just drops into place. It's unfinished I still need to close up a spot or two and insulate it some how for full benefit.
Draws air mostly from fender well and behind head light. I have considered adding a good vent that duct right into it but... not yet.
Oh made from scrap at work, cost $0.00
. Besides I'm not sure how much that would actually help. I'm thinking about trying to find something a little thicker and lining the inside with it...BUT I may use reflective tape since it's already purcahsed and see if it makes any difference. The front lower portion still needs to be closed up. I'm thinking about trying to make a track on the sides and have a piece that can side up from the bottom around the intake to seal it completely, just either have a pin hold it in place or a spring for quick and easy install/removal.
