FP Race manifold heat shield?
The hose on the dipstick is just some high temp silicone hose from napa I believe(which comes in the ugliest color possible ROFL ). I put it on there so the heatshield didnt rattle or rub on the tube. You can see I also used it on my turbo coolant lines.
And if all you need is the top shield its even more simple to make. Heres some good links
http://www.dsmtuners.com/forums/custom-fabrication/351940-aluminum-heat-shields.html
http://www.dsmtuners.com/forums/art...07650-make-your-own-manifold-heat-shield.html
Thanks for the compliments on the blankets guys. Glad everyone is pleased with the performance so far. Happy to answer any questions anyone might have about them.
Levi
BBFab will then need to become a vendor on here and set up the group themselves... forum rules.
Bumping this up, I've got a new heat shield fabbed up to fit the FP manifold, made out of brushed stainless, attaches with no visible bolts. You can see more pics in the Freelancer section or PM me.
Nice!
I made mine out of s sheet of stainless. It doesn't completely cover it up, but it seems to work pretty well.
I used the spot by the timing cover and the one where the oe shield bolts to the turbine housing for mine.
I am by ohare....that background is actually in detroit. I go back and forth between chicagoland and detroit a lot. :)
Any better pics of the mounting points? I don't have a DSM anymore just curious. I am 15min west of ohare
I will look through the folder of photos once i get back home, i should have some better pics that show the mounting points.
And cool! Perhaps will see you around!
