FP Green/Tial MV-S Wastegate/ECMLink
Bedicine
542
189
Jan 3, 2022
Toronto, ON, Canada
Hello,
I just purchased a 38mm wastegate (Tial MV-S) and am trying to figure out how to install it. It will be paired with an STM 02 Recirculated housing , i have seen so many different methods of using the top port opposed to just the side port and am trying to figure out what is correct. This will be paired with Ingersoll-Rand/ARO 3-port Solenoid electronic boost controller
This is where the additional confusion is coming from. It shows the top port being used. Majority of the write ups on here don’t use the top
Does the top port add additional pressure on the spring making it close faster or anything of that nature if both are used?
This covers essentially every boost control configuration you would ever need to consider and the benefits of each. See if this clears up your questions.
