Punishment Racing O2 Dump W/Tial MV-S
I have the Recirculated 02 with the tial, it works really nice but you must eliminate the a/c fan as there is 1" clearance to the radiator!
I have the dumped version on mine and theres more room then the recirced. I think I have almost 2 1/2 inches of clearance wiith a thicker aluminum radiator. Will soon be buying the dual FAL fans made for our car.
Beautiful engine bay. Is that the fp intake with the 9in kandn filter? I have the intake and the filter is on its way I hope it fits just as good on mine.
You'll need to eliminate the OEM A/C fan, but you can always install a pusher on the condenser and then put a line of foam down the center between the condenser and radiator to separate the pull/push of the fans so they work independently.
Starting thinking now, I have a Mishi radiator with the dual fan shroud. Will that fit fine with the MVS? Same setup as CHAR-FT.
Here is my MVS WITH stock fans and radiator on my 2g. :hellyeah:
    • Sdcryan1
