VanIsleDSM
- 407
- 4
- Aug 23, 2006
Victoria,
because the FP30 housing is larger wouldn't it spool slower?
I don't have any first hand experience but from everything I've read the PTE 50 trim spools to ~20psi at around 3500 on a 2.0.. I understand you're at a higher elevation, but it just doesn't seem very fast for a BB 50 trim on a 2.3..
I'm buying a BB 50trim once I get back from work again in september some time.. by then hopefully it will have been released for a while and there will be some more info to compare it to the PTE on spool.. I'm sure it'll flow better and have a better top end, but if it hurts spool too much I'll probably just go PTE... or possibly T3 since you basically have to replace everything with the FP setup aswell.. it's only bolt on to the manifold.. not true bolt-on.
Curious why the switch from DNP to the FP manifold? being cast I imagine it would help more with heat even though your DNP was coated.. but it has sharper curves than a DNP and it's not equal length.. having the full setup is obviously alluring.. just wondering what your motive was there and what your thoughts are about which manifold is better and why..
