Ludachris
Founder & Zookeeper
- 8,842
- 4,670
- Nov 12, 2001
Newcastle,
California
Forced Performance will soon have this turbo available to the public. What is it? A dual ball bearing 50-trim turbo using the popular FP30 turbine housing (just like the FP3052 and FP3065). For those not familiar with the FP30 housing it's designed to match up to a Mitsubishi-flanged exhaust manifold and uses v-band flanges to connect the external wastegate and the FP O2 sensor housing (as the photos below show).
I'm using the ceramic coated FP Race Exhaust Manifold with the FP3150 turbo, the FP O2 sensor housing and FP wastegate dump tube for the Tial 44mm wastegate. Forced Performance supplies all of the necessary oil supply and drain lines, gaskets, and nuts and bolts. Since I'm not using factory coolant lines, nor did I have any laying around, I made up some SS braided lines and purchased some fittings online to make it all go together.
The install was pretty straight forward. I found that I had to do a little grinding on the front motor mount to allow clearance of the oil drain line. I also had to get a little creative with the coolant lines. I ended up cutting the water pipe and welding on a -6 AN bung and drilled out and tapped the nipples on the thermostat housing and used 1/4" pipe plugs for the ports that were no longer used and a 1/4" NPT to -6 AN male adapter for the coolant return line. I used a banjo fitting for the backside of the turbo which had a female 1/4" thread to allow for another 1/4" NPT to -6 AN male adapter to connect the -6 elbow.
I took the car out to the road course for a quick shake down and though I had a few issues I can say that the turbo spools very fast. I was only running about 18 lbs of boost and I was seeing full boost at about 3600 rpm. Now that's with very light tuning. I'm going to be playing with it some more over the next couple of weeks to get it ready for another test and tune track day. I hope to have all the kinks worked out soon for some Time Trials competition. I'll be posting more about that later.
Here are some photos:
