fitting?
218dsm
87
Sep 2, 2006
waldorf, Maryland
hey guys!!! was looking at some pics on jayracing's website and found this pic! does anyone know what is for? I assume its for crank case pressure but not sure...any opinions would be great
couldnt i just do 2 fiitings in the valve cover and the one in the head between the runners to allow more relief of the crank case pressure? has anyone ever done this mod and is it worth it? thanks
The most common way I've seen is drilling to 1/4" fittings into the passenger side of the valve cover and running thenm to a catch can. As far as what kinf og performance you're going to get you'd need some check-valves to make sure that the crank has negative pressure, but its only an issue in high boost cars (some of the local DSMers running 35-45PSI on E85).
