fmic fitting
Tough call on the 24in wide core. End tank dimensions are important too, but the ad doesn't give that info. Keep in mind that I have no experience with this intercooler, but I can see it fitting with the fogs if you mount it low with the inlet and the outlet below the brackets. On the other hand, mounting it low puts the IC at risk.
Hey, that IS iffey, in anycase I am selling a FMIC that will allow you to keep your stock fogs. PM me if your interested since this isnt the classifided. Thanks.
I dunno Matt, remember that kit is the same size practically as the Greddy kit that the GST had on it that we went and looked at and he still had his fogs....
The SSauto kit wont allow you to keep your fogs for you use the fog light bolt holes to secure the FMIC to the frame...I have one and I tried every possible way to keep them...
That looks like the SSAuto piping kit with a diff core. It is mising two pipes at least, some couplers and some t-bolts. Look at it and you can tell. I would possibly buy that core, but not the kit
