xXEclipse
- 470
- 1
- Aug 30, 2010
Montrose,
California
Me and a buddy are looking at going to the strip next Thursday just for fun. Any tips or info you guys can give me? He told me its 1/8 not 1/4
I see your in So-Cal, is irwindale the track your planning on going to?
Since you have a gst be prepared to feather the gar or you'll spin half the track. The first time I went there I spun almost the whole track.
Sent from my DROID2 GLOBAL using Tapatalk
Ill be there on Thursday also with my car. Say what's up if you see me ill be in the green 2g with gold rims in the back and slicks in the front.
You should also look on their website to make sure your car will pass tech.
Good advice on the throttle control. Go there with about 1/4 tank to save some weight. Take your spare tire, jack, tools, subs, etc out as well. Passenger and rear seats if you want to go extreme. Most importantly.... try not to break anything. Lmao
Sent from my PC36100 using Tapatalk
I'm usually at Irwindale every Thursday. Tech isn't too picky at all just be sure you have: All your lugnuts, battery tie down, a helmet (if your car's fast enough) and just generally nothing obviously ghetto like a gatorade bottle for your overflow tank.
Ill try and get or make a tie down, I guess the lug is my other concern, Ill take a pic lemme know what you guys think.
Also, the neutral safety switch, is that the switch by the clutch so you cant start the car without the clutch in?
Anyone want to comment on taking the back seats out?
i see your in so-cal, is irwindale the track your planning on going to?
Since you have a gst be prepared to feather the gar or you'll spin half the track. The first time i went there i spun almost the whole track.
Sent from my droid2 global using tapatalk
all tracks here are 1/8.. The nearest 1/4 one is in l.a
I'm heading back one more run with the t25 to break into 14's and then the big16g goes in somewhere in July for 13 sec pass. Just to let you know, hitting 13's aint no joke!It's a white switch above the clutch pedal assembly your looking for. I think it's just called the clutch switch. Anyway if you pop your head under and look up you will see it. Don't disconnect the one the actual pedal that is for cruise control. You need to look farther up and there is a two wire white connector that's the one you want to unplug. Then just make sure you always leave the car in neutral and it will start without the clutch. To take out back seats is easy, first lift out bottom part by pulling the taps on front side there are two. The. You will see four 12 or 14" bolts holding the back rest down. Just remove those and the come right out. You probably won't see much gain from just the rear seats removed. I always take this out everything in the trunk and my passenger seat. That makes for a quick and easy weight reduction.
