1G First gear engagement issues
I have checked and made sure my shifter, baseplate and bracket are correct. And that they are not from a 90 or 2g.
Sounds like you have multiple issues with the clutch, shifter and trans, and have to diagnose and fix each separately to get this right. Similar to my situation. Old cars, old parts, things wear out, sometimes independently and sometimes compounding each other.
For example, as I wrote above I can get my trans into 1st but it usually pops right out, even with the clutch pedal all the way down. My guess is that the clutch pedal developed the infamous slop issue years ago, so the clutch never fully disengaged (which I didn't realize at the time), which wore down the 1st gear synchro to the point where it was nearly gone (and probably wore down the others just not quite as bad), and perhaps the hub, slider and even gears. Now I have to fix both, as well as restore the shifter bushings as you have.
Btw, what do you mean by "left shift cable"? There's a select cable and a shift cable, corresponding to moving the shifter left-right in neutral to SELECT between 1-2, 3-4 & 5-R, and up-down to SHIFT into one of these gears. Which are you referring to here?
I'd have to guess it his select cable.
That is a a stock rebuilt shifter BTW. :)
Mine's coming out soon and getting a nice cleaning, painting and rebuilding. Is that the condition most 1G's are in these days, rusty and grimey, with rotted bushings?
And how do you fleshly rebuild something? ;)
You powder coat it all. ROFL (sorry)
I have a buddy that did all of his and it looks great!!!
Mine is surface rust from 1990. My sandblaster isnt up yet but this shifter is nice and solid so she will go into the red 90.
Eh, I've had good results with wire brush and abrasive wheel drill bits followed by primer and paint. Doesn't reach show car levels but that's not what I'm going for. I like things to look "clean", not spit polish perfect. As soon as the car's driven all that's gone anyway.
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
