General Fic 1250 blue max settings
SasaniFab
2,432
788
Dec 1, 2013
Mexico, Connecticut
Hey guess, I'm still trying to figure out why my duty cycle is so high. I have a set of 1250 I want to swap out to see if it helps. I can't seem to get the car going I'm currently trying -64 and 330? Any help would be appreciated
I've been in your shoes. Let me get my computer fired up.
What DID you have in the motor and what were your settings for them, do you know? AND gas or E85?
So on gas its "suggested" setting is -66.8 and on E it suggests -50.2 then deadtime is what will get you started up. Try 440 to start with then play up or down from there. My Blue Max 1650's are set at -52.3 and 465 DT for an example which isn't what Link suggests (-62.3). Is it perfect, no. Does it work, yep. I couldn't get my car to start or run on the suggested values but my tune is skewed lean. Just giving you some starting points and my values when I was in your spot.
I'm gunna try that, I can't get my injector duty down for the life of me
