ECMlink FIC Blue max 1350s come with problems
nightmares GS-T
332
3
Aug 18, 2009
Pearl, Mississippi
Alright I recently installed my new fic bm 1350s and havent been able to get the tune quite right. Open to any and all suggestions so please give me a hand. Using Link v3 full. Also cant seem to get my glowshift wideband to log correctly.
Not sure what exactly your tiring to do from looking at you settings. An don't personally think your thread title is the best as I run BM 1450's an have had ZERO Problems... It's not the Injectors fault.
So, Really kinda need more info on the setup and I'm guessing you Mods list is outdated...
But, Also you Need/Should update your firmware... Looks like you don't have the newest version. an updating it will give you the most functionality.
See Here for firmware changes.
Make sure BEFORE trying to update your firmware, to update to the newest Laptop program For Ecmlink.
WIN here
Linux
MAC OS 10.4 Here
If you don't now how to update it here's a How to.
Did your Injectors come with a Injector flow an Latency sheet?
I have tried updating my firmware and everytime it gets to the very end and then says no connection found. Ill see if using the newest software helps. As for flow and latency yes it came with a sheet I cant find it at the moment but they all flow tested at 1340 cc. As for mods no the list is up to date other than link not being listed and the new injectors. Basically it runs lean. I notice between 2-3k rpms it goes pretty lean while accelerating and knocks a little. Ive turned the fuel up some bit it doesnt help. Im thinking its something to do with my maf comp curve. Also the entire tune all around is too lean and I cant go over 4-5psi of boost before it leans out and starts knocking and or missing. Sorry I should have clarified my issue a bit more.
I cant find any Info online about dead times with the BM 1350's. Is it 330 like the rest of the FIC injectors?
No, I see most guys running around 600-800 µsecs.
OP- Exactly how lean are you running? What fuel type are you using? For starters you need to find the sheet with the correct settings and get your wideband to log correctly. A WOT log would help too, your idle logs don't show us the issues your describing.
But from what I can see, your fuel tables are targeting pretty lean AFR's. Even leaner than the Evo8 GSR maps. Where are you adjusting fuel? I'd start adding fuel to the DA tables. Maybe even just load the Evo8 tables.
