Few misc. questions
coryf1233
246
Nov 6, 2007
hanover, Pennsylvania
1) Can someone varify that it is normal for egt to be hotter during boost.
2) If crank pulley has some minor damage, should it be repalced asap
3) On cold start idle is at 2000 and at normal operating temp around 1100 what should i do to lower this..or is that decent.
1100 isnt bad but you can lower it with a screw driver ( philips) on the throttle housing there is a screw that you tighten to make the idle higher and loosen for it to drop it should be by the throttle body
yes its normal for your egt to get hoter as the car builds boost your makeing the car go faster inturn burning hotter
on your question number 2, about replacing the crank pulley, i would say replace as sooon as you can. I haven't had any trouble with my dsm's pulley, but with some on my cars in the past, just casued me many headaches.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
