2G Exhaust causing fuel cut?
1998eclipsegstdsm
Jan 31, 2017
New windsor, New York
ever since I did a turbo back my car has fuel cut when I go wot but it isn’t consistently doing it but if I punch it, it will fuel cut bad. Could the exhaust be causing this? My car also doesn’t have a stock air box it’s just the stock intake tube to the maf to a filter. Could this also be causing fuel cut? If these two are causing fuel cut then how could i fix the problem?
Your probably getting boost creep from your exhaust which would cause fuel cut if you don't have supporting mods and tuning. What manifold and o2 housing are you running? If stock then you can port to help with the boost creep. Make sure you have an aftermarket boost gauge also.
Agreed! that or your knocking and timing is being pulled hard.
Are you sure its fuel cut? What does it feel like?
And you need a profile page. More difficult to help if we dont know the car.
Stock manifold And o2 housing where could I get a ported o2 housing?
It feels like my car hits a brick wall and it completely dies while I’m still in it my car literally only has the two things that I said in the original post
What could be causing knock?
In addition to what creating a profile like @pauleyman suggested, you may consider the following:
  • Need a boost gauge
  • Wideband o2 sensor to monitor AFR's
  • Get a method to log
    • ECMLink
    • EvoScan
  • Pressure test intake
  • Test waste-gate actuator
  • Inspect spark plugs
  • Inspect knock sensor for physical signs of damage (oozing)
The stock turbo (t25) and fuel system should not see more than 15 psi. Even that is a little high without at least a rewire of the fuel pump.
  • For sale Carbonetics Carbon Quarter glass
    Bnew Carbonetics Quarter glass
    • jabo97gst
  • Wanted 1g Wtb: Palm pilot w/ MMCD and cable
    I am doing an old school build with my 1G and am looking for this ancient hardware. Preferably...
    • Jeff D
