Evo VIII Cams in DSM? [Merged 5-9] 8 cam
acidxrain
32
Oct 20, 2002
My friend is upgrading the cams on his evo VIII so he'll be getting rid of the stockers. Would the stock evo cams be a good upgrade for my car (97 gsx)?
1SloColt said:
The evo8 motor is not turned 180, it is not reversed in any way either. The motor is mirrored compared to 1g and 2g cars. Think hard and long about what mirrored means and try and picture it in your head before you chime in.
The thread starter never asked about the evo motor, he was asking about the cams, and if they were an upgrade, and never got back to ther post of whether or not they fit. I think some people are curious to the results of his "mod" and how it worked out. I would've never touched it being 2 yrs old though. :p
Mike
Mike
Obviously you didn't think about what 1slocolt said:toobad: .
No biggie. So if the engine is mirrored? Are the cams mirrored? . . .
Since the cams are mirrored are the cam timing events mirrored? . . .
So cam timing events are morrored? Will cam timing events that are mirrored be like unmirrored cam timing events? . . .
Do cam timing evens have a tremendous impact on how an engine runs and flows? . . .
NO doesnt fit plan and simple NO!!!!!!!!!!!!!! Anyway buy some, COMP,HKS,FPs whatever instead.
I have 272s and love them
Lol its funny people still even think these will fit, You can use EVO8 pistons in your car since they are better than 2Gs and are stronger now that is true.
I know 3 people running Evo8s so that is the only thing you could run.
why you gotta be a dick about it? tired of people being smart ass's, if someone dont know or understand something dont be a prick about it. ^ not everyone has the $ to go out and buy some 6-700$ cams if they did do you think they'd be debating if evo cams would work?
flacopower said:
how is this moron a proven member i am still a newbie?? anyways when you say minor modification what does that mean? i wouldn't want to be modifing too much in that area of my car..
this kind of stuff is what Im talking about
Cripes, I just love how people nic pic and say the exact same dam thing. Getting specific. NOTHING is mirrored. Nearly everything is new and not left from the old 4G63. Look at the head, valve cover, exhaust manifold, trans bolt pattern, etc. None of those are mirrored parts. More so, not getting that specific, the block is turned 180, the head is mirrored. If the engine was mirrored, it'd rotate in the same direction.
Now regarding if they work or not, I don't think any one has tried here. Lots of hearsay, but no one as actually done it or tried. To those claiming it's been tried by wisemen, please point us in the direction of the threads.
I am the one claiming that I trust wisemen's opinions over your speculation.
Can a Moderator please close this thread? It has gotten rediculous.
The lift and duration on these cams hardly merit the effort it will take to swap them, even if the cams were to fit properly. All they offer really is a lighter weight.
Do you people really think that no one has tried to swap evo8 cam's into a dsm? Or, do you think it's a builders secret?
But if you must chew, chew on this instead of your speculation:
http://www.dsmtuners.com/forums/showpost.php?p=1752799&postcount=44
http://www.dsmtuners.com/forums/showpost.php?p=1653428&postcount=2
http://www.dsmtuners.com/forums/showpost.php?p=1654433&postcount=6
http://www.dsmtuners.com/forums/showpost.php?p=1631874&postcount=7
I would have to agree on the closing. Best way to find out if you are skeptical is to try it and find out. I think I have tried a crap load of trial and error to find out what will work and what wont. And seriously, some of the people everyone is arguing points to have probably not been on the site in quite a while, so it is like beating a dead horse. And dsm-onster, I was never doubting anything anyone said, just to clarify.
Mike
True, I mearly asked nicely.... I even said please.
And I was referring to this,
dsm-onster said:
I have seen several threads where wizemen have said the evo8 cams will not work properly without significant changes, given that the camtiming events are in the opposite direction for opposite cams ...
Which leads me to believe a wisemen has tried it. Or heavy discussion has taken place before. So, you can shed some light by posting the threads you were referring to. :)
Yes, I see the posts after his edit (which happened while I was posting :) )
dsm-onster said:
Thank you. :thumb:
For the sake of discussion, in neither case did he try it. In the first link, if you rotate the cam (like it runs in the engine) , then it's the same. I don't really follow the logic there.
Not to go off topic,dsm-onster, how do you edit without it showing you edited your post??
I don't see anything really being said that hasn't already or any proof of anything. Just a bunch of people going, "Come on anymore info?"
Why doesn't someone from this thread actually try it for yourself.
I will re-open this thread but it better start getting techical and less posts saying "any updates" just to bump it or I will reclose this.
No worries Bro. If I had the evo8 cams, I would go for it and give the results. But that is how I do everything.LOL
Mike
Any donators on the cams for this little test?????
Call up AMS and ask them for your selfs, why are HKS say for EVO8 and ones for our cars say 4G63. Different desing but the same motor, EVOs heads are different from 1g heads.
