2G Engine mounts
Rockauto shows the same numbers except for the Transmission Mount - Left
Here is a link to the site:
https://www.rockauto.com/en/catalog...4,transmission-manual,transmission+mount,8756
The front and rear mounts are the exact same between the 4g63 and 420a versions. You'll be fine to use those billet mounts you mentioned.
I can’t tell as far as the back one but the front motor mount on my 420a is the same as my gst spyder.
thanks for all
The front one should be the same. The rear one should be a mirrored part, so it probably won't bolt into the subframe properly. Could be wrong, but that's how I've remembered it. If you look at these two pictures, the top one is my GSX, the bottom one is the GS I had a couple years ago. The mounts do look the same, but if you look closer, the mount itself looks to be in slightly different spots on the base plate. I say try it, the worst that'll happen is you can't use it.
