blcknspo0ln
DSM Wiseman
- 7,772
- 102
- Jul 31, 2003
Central,
New Jersey
Ok so the block is at the machinist and he says everything looks good to go. Rod #1 will be reconditioned, piston skirts are lightly sanded with 600 and the block is being honed. I had a couple questions on specs and would like some more insight from you guys.
Big woo recommended these specs:
0.0020 on the rods
0.0025 on the mains
As for ring gap, I was doing a lot of research and ross mentions .004 x bore +.004 for turbo app. on their rings. As an example through Ross:
3.625*.004 = .015 (for nonturbo)
3.625*.004+.004 = .019 (for turbo)
My machinist recommended running .0065 per inch of bore so in that same example it would be :
3.625*.006 = .02175
3.625*.0065= .0235625
Not looking at the bore size, since I don't remember what he told me off hand, is the difference from the ross recommended of .004+.004 to the machinist recommended .0065 (which is a difference of .004) make that big of a difference? I know gap is very important, so what spec would you recommend for the rings?
Lastly, .006 for PTW clearance is the ross recommended gap. I will ask again what my machinist measured and would like to know what the standard is and what is considered too tight and too loose.
Thanks guys!
__________________
0.0020 on the rods
0.0025 on the mains
3.625*.006 = .02175
Thanks guys!
__________________
