Engine Bay Cleaning!
gotmyeclipse
130
Jun 26, 2012
Hayward, California
Just wondering what do I need to cover when washing my engine bay? What are the parts that's not Okay to get wet. Thanks!
Anything electrical like sensors,it won't hurt turbo just make sure engine is cool I do it all the time
If your air filter is exposed make sure you cover it up with a plastic bag or something.Also make sure your spark plug boots are in all the way.I recommend you blow the engine off with air after to dry it as well.
I have used gasoline in a spray bottle and a wire brush for years to clean it up. Then I just hosed it down when I was done. Unless you got some hack job wiring I don't see a issue happening.
That is an awful idea. First off the whole engine bay will smell like gas afterwards. 2nd gas isn't water soluble so it won't all wash off when washed with water. 3rd it is flammable and easily ignited with a spark or flame. 3rd a wire brush doesn't do do so good on painted surfaces. There are several cleaners out there that are light years better than gasoline for cleaning engine bays such as purple power and simple green. They are non flammable, non toxic, bio degradable , and the fumes won't kill your lungs. They also clean better.
Don't knok it till you tried it. I'm not saying go do it if your not comfortable. I have have been doing it for years. No I don't ever smell gas after I do it. All I see is a clean engine bay.
Very true - bad idea using petrol as a cleaner...!
Hit Home Depot, Costco, or the similar and get you a gallon of classic, "Simple Green" !
Use undiluted, right out of the jug into a spray bottle and nylon bristle brush, shop rags, old terry cloth towels and similar (even used tooth brushes are great as part cleaning brushes).
Cuts through grease, cleans rims, wash windows with - anything that needs cleaned, Simple Green is the answer..
....AND, it's biodegradable, washes off with water and non-flammable.
You can use it to clean auto parts with (I used Simple Green when I do carb overhauls and just rinse with water and does wonders) and washing hands with with a scrub brush to get hands clean after they've been black with engine grime.
And it's totally safe to use. Be smart, for it won't hurt you! - DSM
I never covered anything, ever. I worked in a detail shop. We just spray everything down with the cleaner and sprayed it all off with a pressure washer. Did it for 4 years. The only thing it messed up was corvettes. They would die and not start for a couple houres.
Just curious, why would distilled water be different.?
Water is only conductive when it contains ionic compounds, which are naturally picked up from the environment. So if you remove the impurities (distilling), you remove what makes it conductive.
For engine bay cleaning, I just unhook the battery and cover my K&N. Then spray everything with a 70/30 mix of purple power/water, scrub the tough spots, rinse thoroughly, and let dry completely before use.
what about the alternator and coil packs? are they okay to get wet?
yeah you can get the alternator and coil pack wet. The best bet to clean the engine bay is leave the car running spray simple green everywhere, cover filter, battery, and be careful with spark plug well other then that just hit it with a power washer while its running. Then hit it with some air to dry everthing up.
thats a good idea, but whats the difference between simple green and an aerosol degreaser?
You probably don't smell gas because your sinus passages are damaged after inhaling all the gas fumes and aren't capable of smelling much afterwards. How can you say that the engine bay won't smell like gas. If you spill a little gas on your intake manifold from removing the fuel line it will smell like fuel for a week. I have cleaned plenty of things with gas, 15 years ago when i first started messing with cars. I soon learned that there are better products out there that do a better job.
Gasoline is a good degreaser, just use it wisely. Dousing your whole engine with gas isn't wise.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
