1G ECU Problems
Laserfreak
Jan 11, 2018
Victoria, BC, Canada
Hi,just sign up and I was wondering if anybody would know were the sensor ground is located in the ecu for a 1991, Plymouth Laser,have two ecu’s one when I plug in with key on,didn’t light up,so I figure bad sensor ground and other ecu plug in,get constant light cel on ,not turning off,means code stored,but need to buy code reader,
What didn't light up with the first ECU? The check engine light when you first turned the car on? What sensor ground? Do you mean the ECU ground? Grounds are listed in the 90-91 electrical manual:
https://www.scribd.com/doc/15602873/90-91el
I'm not as familiar with 1gs as I am with 2gs, but if I'm not mistaken, ground #7 on page 8-5 is the main ECU ground.
You don't need a code scanner to read codes on a 1g, just a cheap analog volt meter:
Jason...here's a quick guide to a simple test and link to code list:
http://vfaq.com/mods/wayback/BradBauer/electrical/code.html
An awesome amount of FAQ answered:
http://vfaq.com/index-main.html
More likely capacitor leakage problems with both ECU's, have you opened them up yet? If so take pictures and post them.
Here's a easy way to read the codes or check for the ECU heartbeat. http://www.dsmtuners.com/threads/1g-code-reader-cel-code-reader.319844
1G ECU pinout http://www.dsmlink.com/images/forums/1GECUPinout.pdf
Shows that the sensor ground is pin 17 and the ECU ground is pins 101 and 106.
1G ECU Wiring diagram (MPI Circuit) http://www.dsmlink.com/images/forums/1GECUMFI.pdf
Shows that the ECU is grounded to the chassis at ground #7 which is on the right hand center console support passenger side.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
